Is anyone having trouble with Matrix Objects? I’m in OS 10.14.5… Pan X is v. 10.1.2 (2854).
In a new database file, I create a Matrix and frame object using the Constructor, and it works. I have a Text Display object in the Matrix Frame, simply showing a text field from my database, and I stuck an Oval in the frame as well. Pass Thru is ON. But…
The special object properties sub-panel eventually goes blank. The only way I’ve found to restore it is to quit and relaunch Pan X (a pain, of course). This happens repeatedly after working with a matrix object on a form, say for 5 minutes or so. When it happens, the sub-panel still works fine for other objects.
Renaming the Matrix Frame object causes the Matrix to stop working (nothing displayed). Of course, I put the new name into the Obj. Name field in the Matrix sub-panel, but it never connects. Reseting the Frame object name to “Matrix Frame” and placing that name into the Obj. Name field does NOT restore the connection. But CLEARING the field does restore it, and the Matrix works again.
In addition, the pop-down menu for the Obj. Name field does not work at all. It always shows one blank line.
