Just updated to the 10.2 beta, and now the Text Editor options sub-panel has gone blank! Relaunching Panorama fixes it. This is reproducible as follows:
Open a file with a Form visible
Switch to Graphics Mode
Select an object
View the Options sub-panel
Switch to Data Mode
Select a same-type object
The sub-panel is blank.
I have just tested this with Text Editor, Text Display, Matrix, and Tile objects. Once the sub-panels go blank, I can only fix them by relaunching Panorama.
The workaround seems to be: DESELECT all objects (click in an empty area) BEFORE switching to Data Mode.
I’m on OS 10.14.5
