The terminology GUID was chosen because that is the terminology Apple used in the API Panorama calls. According to Wikipedia UUID and GUID are interchangeable terms, so the Panorama documentation has now been updated so that this page will come up in a search either way - however, that will only work if you use the “Full Text” search option.
