I have summary fields of Credits and Debits. AT bottom of report I want to have Credits - Debits =( Value calculated)
I have the 2 summary fields in place, but how do I write the formula to calculate the value for the difference in the 2 fields?
Thanks
In a summary tile you would have a text display object with the formula
"Credits - Debits = " + pattern(Credits - Debits, "#,.##")
It just comes out like this. + pattern(Credits - Debits, “#,.##”)
I figured it out, my field names are singular, Debit, and they are all caps, DEBIT, plus the object defaults back to literal text, so I am learning. Thanks for your help, your formula worked, once I got the syntax correct.
