While working with command F on a form, I noticed the following.
I cannot use command F while my cursor is in a Text Editor object. In other words, I cannot use command F in the scenario shown below.
However, I can used command F when I click out of the field Text Editor object, such as in the photo below.
Command F then brings up the Find/Select dialog and searches through the field I most recently edited.
Can I use the command F search function while editing a field in a Text Editor object?
My guess is “no”, because this would interfere with the “Enable Find Bar” option in Text Editor Options. But, if there is an equivalent workaround, please let me know.
Thanks!
