Hello,
I want to display a checkbox outline beside size and price in a formula on a report data tile I’m using for a gallery price label. It will print multiple size/price options and I’ll be able to manually tick the correct one.
When I use a rectangle object, it displays an extra one for the summary record. To avoid this, I want to use the unicode box symbol U+25A2 in the formula. I tried it in the chr() function but got an error. What is the proper way to do this?
Thanks,
Jeff
