There is a text list object that should be populated via a FileGlobal variable.
The variable is a return-separated array containing tab-separated elements.
The variable displays all the data, as expected, in a Text Display Object.
However, in the Text List Object, each line displayed repeats the data from the first element of the array.
Based on the tutorial/example in the “Help” section, this should “just work.”
Prolly something dumb I’m forgetting …
I vaguely remember reading about this at some point, but I cannot find the answer here I the forums …
If the following code is added to the “procedure” of the TextList object, then the correct data gets displayed in the message when a particular row and column is clicked.
I looked at some instance where I am using a Text List object.
I am using a formula that results in a one line array (in the Formula Workshop), but it populates the Text List object with a line for every record of my database. Activating the “Database Navigator” option brings me to the clicked record.
Maybe you have a database set in the Options pane. I believe you need this blank when using a variable or a text string entered in the Formula pane for a Text List Object.
Gary beat me to what I think is the correct answer.
If a database is specified, you’ll see one row per database row. The formula can specify field names which will be displayed from each row. But since you specified a variable, you’ll just see the same information over and over again.
