I previously reported two circumstances that will result reliably in a loop between a client and the server, where the server log shows a repeating pair of log entries, an Automatic unlock entry followed by a locked record entry. This pair repeats until a force quit or other action disconnects the client from the server. I have now found a third way to cause this failure.
In this case, I have a form with one text editor linked to a DB field. I opened the database (Navigator) With a procedure, I opened the form, which contains one text editor. I then pressed the tab key. After a couple of seconds, a spinning beach ball appears and stays until force quit is executed.
The log shows this, from the moment I opened the database (which in turn opened an aux database, until interrupted:
05/14/2021 11:15:27 am Session 44 (MacBook Pro:Thomas Cooper) start of new session 05/14/2021 11:15:28 am Session 44 (MacBook Pro:Thomas Cooper) opened shared database: Navigator 05/14/2021 11:15:28 am Session 44 (MacBook Pro:Thomas Cooper) synchronized database: Navigator (ts:313-313 changed:0 deleted:0) 05/14/2021 11:15:31 am Session 44 (MacBook Pro:Thomas Cooper) opened shared database: Timekeepers 05/14/2021 11:15:32 am Session 44 (MacBook Pro:Thomas Cooper) synchronized database: Timekeepers (ts:102-102 changed:0 deleted:0) 05/14/2021 11:16:02 am Automatic unlock of record 1 in database: Navigator (original session gone) 05/14/2021 11:16:02 am Session 44 (MacBook Pro:Thomas Cooper) locked record 1 of database: Navigator 05/14/2021 11:16:02 am Automatic unlock of record 1 in database: Navigator (already locked by this user) 05/14/2021 11:16:02 am Session 44 (MacBook Pro:Thomas Cooper) locked record 1 of database: Navigator
In variation of these steps, I revised the procedure that opens the form but adding a changeobject, [texteditorname],“open” statement. This should look just like tabbing into the text editor, and it resulted in the same failure.
Then I change the text editor data to a variable, and no failure occurred. That would not make any call to the server, so I would not expect a failure.
