I want a Superalert that notifies me of a procedure that I execute but I want the delay time to be variable. The variable is File Global variable called “fgTimeDelay”. I have verified that the File Global has a value. A quick procedure allows me to change it.
It works fine if I “hard wire it” such as:
Superalert “Henderson Restaurants”,{timeout=2}
But if I introduce a variable for the value of timeout it does not work. I must mouse around and click the “OK” button.
No matter what I do I cannot seem to format a Superalert with a delay that also specifies font type, size and color plus alert box dimensions PLUS the time delay, which is variable.
Jim showed me the “trick” but if I try to go beyond that the delay does not work.
This works with height and width changes and delay:
You know I saw that space and it did not record in my brain as essential. It was your example earlier. Not really obvious as a necessity! I thought it was a typo!
Noted on indenting code examples too. Forum etiquette one might say.
I have found that the timeout option does not work if you have a timer running at the same time. It seems that all the timers are stopped until you manually click a button to close the dialog. If you have no timers of your own running but have the the Timer Workshop window open which also runs the timerWorkshopMonitor timer the timeout again will not function and the Workshop monitor timer will also freeze until the dialog is dismissed.
Had me scratching my head for some time trying to figure out why I couldn’t get the timeout option to work with the alerts that support it.
