I copied your text out of the forum and into the Formula Wizard. The strip( function absolutely does strip out this character, as this screenshot shoes.
Of course there is a high likelyhood that the text has been changed in the process of copying it to the forum, so this isn’t really definitive. But if the character really is a space (U+0200), the strip( function absolutely does strip it out. The stripprintable( function however, does not strip out spaces, nor is it supposed to. A space is a perfectly good printable character.
How are you doing that? In other words, how are you applying the strip( function to your text?
Spaces are printable, right Dave, just look at what it calls itself.
In Panorama 6 here is the procedure:
Field “E-Mail Address”
«E-Mail Address»=strip(«E-Mail Address»)
«E-Mail Address»=stripprintable(«E-Mail Address»)
;this is redundant but just to see if there was a sequence issue
This runs automatically when you enter data into the cell but I also tried it with running the procedure from the action menu.
If I put a bunch of leading spaces into the text and paste it into the cell the leading spaces are removed. So I was not thinking about spaces are printable, which is absolutely true.
But that leading character that is invisible is not stripped.
There is likely a function for strip leading and trailing invisible and non printable characters but I have not looked for it yet.
Could it be something to do that this character is a Unicode Character and Panorama 6 basically looks for ASCII characters?
I have to try to replicate this again like earlier today on Panorama X but now it won’t do it. I just loaded in the latest b18 version of Pan X so perhaps that is the difference.
I will keep trying to replicate on Pan X but it IS a problem on Panorama 6. Albeit for me a very small problem.
In Panorama 6, but not Panorama X, a non-breaking space will not be stripped by the strip( function. Non-breaking spaces are fairly common in web pages. A non-breaking space is chr(202) in Panorama 6. In your unicode web page it would be U+00A0.
A non-breaking space is option-space on your keyboard.
The strip( function strips non-breaking spaces in both version 10.1.2 and 10.2.0 b18.
