Strange Pasting Problem
I’m sure this is just a simple setting somewhere, but on an intel mac running 12.7.3 and Pan 10.2.0.38 i can copy some text, arrow down one record and paste into the red box in the next record. On an apple silicon mac running 15.3 and Pan 10.2.2b.1 i cannot paste into a red box, i have press "enter’ first to make the box active. All this is in data sheet, and a file that allows it on the intel mac fails on the apple silicon. What am i doing wrong?
On an M4 MacBook Pro running macOS 15.2 and the latest version of Panorama X this works fine. I do this all the time, but I did try it again just now to double check. I have not yet installed macOS 15.3, so I suppose it’s possible that this breaks something, but there have been no other reports of this. Do you have any other software installed on your system that might interfere with the clipboard?
In any case, there is no setting for this. It should just work, full stop.
Even when running on an Intel mac, it’s very important to be running the latest version of Panorama. The b38 version you have installed is almost a year old - many many bug fixes since then.
