StartNewDatabaseGeneration and summary records
My procedure crashed because of some programming errors, after I had used StartNewDatabaseGeneration and created some summary records. This left the database locked and waiting for me to UploadNewDatabaseGeneration. However, when I try to upload the new generation, I receive the error “RemoveSummaries statement failed because database is read only,” and when I try to manually or programmatically remove the summaries I can’t because the database is locked as it waits for having the new database generation uploaded.
So I’m stuck. What should I do?
UPDATE: I tried the “Revert to last generation on server” button but it told me it couldn’t download components of the database from the server. So I Aborted the new generation and am now in single user mode. I know a complicated procedure to get back running now. Is there something better I should have done?
UPDATE 2: Now it seems like there is no way to reattach the database (or any copy thereof) to the server. It remains locked.
I’m not 100% sure I understand the sequence of events you are describing. I think maybe you are saying:
  1. You used the StartNewDatabaseGeneration statement to start a critical update.
  2. You ran a procedure that caused Panorama to crash. (You say “my procedure crashed” - does that mean the procedure stopped or Panorama quit and you had to relaunch it.)
  3. I’m going to assume that you had to relaunch Panorama, and re-open the database. Though that doesn’t really make sense to me because then there would be no summary records. But I can’t think of any other scenario where the database would be locked and read-only.
It seems to me that the only way to move forward would be to delete the database from the server, then re-upload it. Then all of the other users will have to download the database again.
