I am trying to change the information in a server variable but it won’t change. Lets say I have a server variable named SV1 and a file global named FG1. I want to change the info in SV1 to what is in FG1. I am using:
setservervariable “”, SV1,«FG1»
The procedure seems to be working but the information isn’t changing. It should, right?
Thank you Jim. I was able to get the server variable to display the updated info, however it still wasn’t displaying the new information on the form. I handled it another way though.
If you used the servervariable( function directly in a form object, you would need to come up with some way to update that object when you think the server variable value has changed. A technique I often use is with a dummy variable. Set your Text Display formula like this.
When you want the Text Display object to update, use this code.
showvariables displayServerVariable
Note that the variable displayServerVariable is never defined, and has no value. It’s only a placeholder that allows you to force the Text Display object to redisplay.
