Hello,
I have ‘patients’ and ‘admissions’ databases’ which are linked through ‘patientID’ field.
The ‘patients’ database includes age of each patient (record).
In the ‘admissions’ database I have a field, ‘admissionType’. It is details about whether the admission was emergency, elective or clinic appointment.
I want to find out all the patients below the age of 18 years who were admitted as ‘emergency’.
I have written a procedure to undertake this search:
openfile "patients"
select «Age» < 30
selectrecordsrelatedto "admissions","SOURCESUBSET",{admissionType = "Emergency"}
Well, my code does not work.
However, is there a way to do this search with ‘Find/Select’ menu dialogue rather than writing the code.
Thank you!
dave
2
It could be done using a formula in the dialog.
I don’t have the appropriate databases to test this, but I think this code would work.
select Age < 30
selectrecordsrelatedto "admissions", "MODE", "selectwithin", "SOURCESUBSET", {admissionType = "Emergency"}
Not for nothing but just to point out you said you were looking for patients below the age of 18 but your select shows Age < 30.
Do you mean Age < 18?
@dave, Thank you!
The code worked nicely.
However, the formula did not seem to work.
The files (they contain dummy records) can be downloaded from:
The variable is lower caps, ‘age’
Thank you!
@designer Sorry for the typos. I mean <30 years.
@dave Thank you again for the formula. With slight modification, the formula worked:
age < 30 AND lookup(“admissions”,“PatientID”,PatientID,“admissionType”,“”) = “Emergency”
