I posted this in May but the problem continues. I don’t want scroll bars on my forms and even though I check off the boxes and save the file, they return when I switch to a different form or the data sheet then back. Closing and reopening the file will often turn the scroll bar boxes back on. Since all the form objects are visible in the window, accidentaly scrolling gives a blank screen that causes user confusion.
I replied to you back in May and you did not reply further, so I assumed the problem was resolved. Note that no one else has chimed in on this.
What does this mean? Unlike Panorama 6, Panorama X does not have an option in the menus to switch to a different form or to the data sheet within the same window. Choosing a form or the data sheet from the View menu always opens a new window.
This is just a hard no - simply closing and reopening a file will NEVER turn the scroll bars back on. You are doing something additional that you are not telling us about, perhaps you are not aware of whatever it is.
