I can’t seem to get a dialog window to respond to the timeout option using the rundialog scheme. Nothing closes after the allotted time out value in either a normal or sheet dialog. Also, with an “OK” button set as default, the dialog will not close with an Enter or Return keystroke so the button itself must be clicked to close. The button has only resume {} in the code panel and the rundialog code is:
loop
rundialog |||
Form="Alert Tests"
sheet=true
Menus=normal
Height=216 Width=324
timeout=10
stoploopif info("trigger")="Dialog.Close"
endloop
I tried a superalert and the timeout option has no effect there either. Enter and Return keystrokes are also ignored for the default buttonl.
