Revert causes crash
In the process of writing a new procedure, the field NameOfRecipe got filled with a number and the database somehow got inadvertently saved. When I open the file, the number shows in the name field. RevertTo allows me to go back a couple of days, where the name does appear, but instantly when I click SAVE on the menubar or my Save button, Panorama crashes. I have tried this five times. Any suggestions?
Try to close all forms and procedure windows and have only the data sheet open when you use the RevertTo feature.
Thanks, but no luck. Pan shows correctly after RevertTo with only the data sheet open, but clicking anywhere crashes Panorama.
IMHO that Apple feature isn’t very reliable. If you have Time Machine backups going back to an earlier version via them is more often successful.
Thanks for the suggestions. In the ‘bad’ saved database, I had created a dummy field with a concatenated value of date and name, so I was able to use that to properly fill with the name. RevertTo seems certainly unreliable.
