Replacement for Chunkfilter statement
Hello,
I’m finally having to convert my heating system controller software from Panorama 6 to Panorama X.
I’ve used the chunkfilter statement to reverse a a text string returned from reading a pulse counter script.
Here is the portion of the procedure using chunkfilter:
local counter
        counter=1
        loop
            pcHex=""
            pcHexResponse=chunkarray(pulseCountersLogShell["9",-1],chunkNumber+counter,8)   //SAMPLE FROM pulsecounters.text:A5200090000001FFFF000000000000B7000000341A00000000000000000000000000000126
            chunkfilter 2,pcHexResponse,pcHexResponse,assign(import()+pcHex,"pcHex") //REVERSE ORDER OF BYTES
            executelocal {pcCounter}+str(counter)+{=radix("hex",pcHex)}                         //CONVERT TO DECIMAL NUMBER REPRESENTING COUNTER VALUE
            counter=counter+1
        while counter<5
I can’t remember why I’m reversing the byte order, but it works, so I need a workaround that doesn’t use the chunkfilter statement and wonder if it’s obvious to someone. It’s been so long since I’ve been programming, my brain is very rusty.
Thanks,
Jeff
You’ll just have to write your own loop to do what chunkfilter is doing. It won’t be quite as fast, but the code should be straightforward.
If your comment
is accurate, I don’t see how this code could possibly work. The radix( function is going to return binary data, not a numeric value. Is that what you want? How can reversing the bytes be what you want?? After this code is done, what are you doing with the variables pcCounter1, pcCounter2…pcCounter5? If this was my code I would very carefully re-engineer the logic, to make sure I understood what is actually going on.
I’ve got to talk with the 1-Wire folks about why I needed to reverse the characters, but the procedure calculates the gallons per minute flow from the pulse counter outputs.
This turned out to be easier than I thought it would be. I used text funnels to reverse character pairs, as it was only filtering an 8 character string.
pcHex=pcHexResponse[7,8]+pcHexResponse[5,6]+pcHexResponse[3,4]+pcHexResponse[1,2] has the same output as the chunkfilter.
And here’s the whole procedure for context.
Thanks,
Jeff
//Procedure reads log file from pulsecounters.sh, parses data and converts it for gpm readings
call .callingProcedureName
onerror onErrorCode
fileglobal previousTimeStampShell,currentTimeStampShell,loopTimeShell,
    currentPulseCounter,pcHexResponse,pcHexResponseFiltered,pcHex,
    pcCounter1,pcCounter2,pcCounter3,pcCounter4,
    lastpcCounter1,lastpcCounter2,lastpcCounter3,lastpcCounter4,
    solarGPCount,solarWPCount,tankPCount,boilerLoopPCount,
    solarGHZ,solarLoopHZ,tankHZ,boilerLoopHZ,
    logShell,pulseCountersLogShell,chunkNumber,firstRound
define lastpcCounter1,0
define lastpcCounter2,0
define lastpcCounter3,0
define lastpcCounter4,0
define loopTimeShell,10
logShell=""
debug
retryloopaction “logShell=replace(fileload(folder(resourcesPath),"pulsecounters.text"),lf(),cr())”,{sendoneemail "","jhdean@mac.com","ALERT Error loading pulsecounters.text. Check network connection for pulsecounters.",logShell rtn},4
if logShell≠""
    pulseCountersLogShell=arrayfirst(arraystrip(arrayfilter(logShell,¶,{?(import() beginswith "A5",import(),"")}),¶),¶)
    currentTimeStampShell=val(striptonum(arraystrip(arrayfilter(logShell,¶,{?(import() beginswith "time",import(),"")}),¶)))    //PARSE FROM SHELL LOG WHICH USES A MILLISECOND TIMESTAMP. MILLISECONDS SINCE THE EPOCH
    define previousTimeStampShell,currentTimeStampShell
    if currentTimeStampShell>previousTimeStampShell
        loopTimeShell=(currentTimeStampShell-previousTimeStampShell)/1000   // DIFFERENCE IN SECONDS BETWEEN POLL TIMES FROM pulse_counters.text FILE
        previousTimeStampShell=currentTimeStampShell
        if pulseCountersLogShell[7,10]≠"9000"    //FAMILY CODE FOR OW-DI08
           rtn  //TRY AGAIN, MAY HAVE BEEN READING FROM WRONG DEVICE
        chunkNumber=4   //FIRST PULSECOUNTER1 IS CHUNK 5, 1ST FOUR PULSECOUNTERS ARE LAST 32 BYTS OF PAGE 1
        local counter
        counter=1
        loop
            pcHex=""
            pcHexResponse=chunkarray(pulseCountersLogShell["9",-1],chunkNumber+counter,8)   //SAMPLE FROM pulsecounters.text:  A5200090000001FFFF000000000000B7000000341A00000000000000000000000000000126
            pcHex=pcHexResponse[7,8]+pcHexResponse[5,6]+pcHexResponse[3,4]+pcHexResponse[1,2]     // chunkfilter 2,pcHexResponse,pcHexResponseFiltered,assign(import()+pcHex,"pcHex") //REVERSE ORDER OF BYTES
            counter=counter+1
        while counter<5
        solarLoopHZ=(pcCounter1-lastpcCounter1)/loopTimeShell
        boilerLoopHZ=(pcCounter2-lastpcCounter2)/loopTimeShell
        tankHZ=(pcCounter3-lastpcCounter3)/loopTimeShell
        solarGHZ=(pcCounter4-lastpcCounter4)/loopTimeShell
        debug
        SolarGGPM=(0.744*solarGHZ-0.2)*0.264172   //CONVERSION FROM CLARK SOLUTIONS VORTEX FLOW SENSOR DATA SHEET, MAY NEED TO ADJUST FOR GLYCOL 40-50%   //Q= 0.744*f-0.2
        SolarLoopGPM=(0.744*solarLoopHZ-0.2)*0.264172
        TankGPM=(0.744*tankHZ-0.2)*0.264172
        BoilerLoopGPM=(0.744*boilerLoopHZ-0.2)*0.264172
        SolarGGPM=?(SolarGGPM=-0.05,0.00,?(SolarGGPM>40,1.99,SolarGGPM))
        SolarLoopGPM=?(SolarLoopGPM=-0.05,0.00,?(SolarLoopGPM>40,1.99,SolarLoopGPM))
        TankGPM=?(TankGPM=-0.05,0.00,?(TankGPM>40,1.99,TankGPM))
        BoilerLoopGPM=?(BoilerLoopGPM=-0.05,0.00,?(BoilerLoopGPM>40,1.99,BoilerLoopGPM))
        lastpcCounter1=pcCounter1
        lastpcCounter2=pcCounter2
        lastpcCounter3=pcCounter3
        lastpcCounter4=pcCounter4
        CyclePeriodGPM=loopTimeShell/60  //CONVERT SECONDS TO MINUTES
        rtn //DONE, BACK TO Live
    else
    firstRound=firstRound+1
rtn
RestartPulsecounters.sh:    //NOT BEING USED
rtn
//[--Restart Terminal.app to restart pulsecounters.sh script--]
;message "restart T gpmshell."
call .Terminal      ;,"restart"    ;,"Pulsecounters.app"
restorecurrentproc
//PULSE COUNTER RESET curltimeout oneWireWrite,"http://"+"192.168.50.89"+"/devices.htm?rom="+"2D0010000025E27E"+"&variable=DiscreteIO1PulseCounterReset"+"&value="+"1"
It looks like you were dealing with hex dumps of 32 bit integers in little endian byte order.
