If the data from a field in a shared database is inadvertently modified or deleted, what clever methods have you found to recover the data?
I restored an earlier copy of the database using time machine, but unfortunately it syncs with the server as soon as it is opened. I briefly took the server down to prevent synchronization and recovered the lost data.
Is there a secret-hidden key combination (Jim?) to prevent sync to the server when opening a file, or am I missing a simpler way of using time machine.
BTW, if I open time machine while a PanX database is active, it briefly shows a side-by-side copy of the database and then exits time machine. Is this direct support of time machine with Pan X under development?
