Hi, and thanks for reading.
I have a field that I want to concatenate several other fields into. Right now my formula looks like this:
Accounting + Baking + CleanupSetup
And the resulting field is all three of those without any spaces/commas. Like this:
AccountingBakingCleanupSetup
I thought about adding + ", " between each, but then if fields are empty there are lots of extra commas.
Is there a way to craft a formula something like, “Grab data from these fields, put them together with commas in-between.”
Thanks for any direction - I’m sure it’s in the documentation but I think I’m having trouble coming up with the right terminology to search for.
Thanks again,
Biagio
gary
September 27, 2019, 12:27am
2
Try:
arraystrip(Accounting +", "+ Baking +", "+ CleanupSetup,", ")
This will add the field values together separated by a comma and space and then the arraystrip( function will remove any extraneous comma/space separators containing blank field values. If all the fields are empty the result is an empty string.
The sandwich( function is handy for this sort of thing.
Thanks so much, Gary! That totally worked. Appreciate you taking the time.
Best,
Biagio
Thanks Bruce! I definitely wasn’t searching the documentation for “sandwich” - but I found it now! Have a great night, and thanks for the tip.
Biagio
admin
September 27, 2019, 2:21am
6
I have three suggestions for you to investigate, two of which have already been mentioned - arraystrip(, sandwich( and yoke(. I use all three at different times.
I vaguely remembered yoke(, but it is not listed in the Help documentation’s See Also for sandwich(. I guess that should be added.
Thanks so much, Jim! Looking them up now. Appreciate the direction.
Best,
Biagio
