I’m trying to get a leg up before Tuesday’s class, and have been playing with related(
to fill in information from a source db into a form in a target db. At first it seemed to work just as it should; but then I started getting this message in the TDO I was working with: "Join failed because first parameter is not a valid dictioanary."
(sic) Here’s the formula for the TDO:
related(Address, "New Pan Alex Mail Exp")+ignore("",«First Name»+" "+«Last Name»)
The relation between the two DB’s is working fine for displaying field contents, also I got it to add new names to the source DB if they weren’t already there; so the basic relation between the DB’s is apparently correctly set up. I can’t figure out what I accidentally changed between when it did work and when it didn’t. The presence or absence of the ignore function doesn’t affect the problem; neither does the presence or absence of quotes around the field name.
I’m sure you’ll explain this Tuesday, but if you can help me now I’ll appreciate it and be a smarter listener in class…
Thanks!
