I was assuming that Z = yoke(Z, ",", n) would be slower than Z = Z + "," + n because yoke( involves two comparisons to see whether the first or third arguments are empty. But it hadn’t occurred to me that Z = Z + "," + n involves two string concatenations, and I don’t know how long they would take in comparison.
You’re right: averaging a thousand results to allow for external factors, I find my version to be about 5.5% quicker than Dave’s — but both under 6ms. Increasing the number of items created in the array from 94 to 10,000, my version (with arguably more in the loop but without the extra statement at the end) becomes about 1.7% slower than Dave’s — which is the kind of difference I meant by ‘fractional’!
Following up on the bug report aspect of this thread, it looks like every 32nd time through the loop, the first statement in the loop is executed twice. If I make that statement a NOP, the results are correct.
let Z=""
let n=6 //first number of the array
loop
nop
Z=Z+","+n
n=n+1
stoploopif n=100
endloop
Z=Z[2,-1] // gets rid of the leading comma
This might be related to a previous discussion with loops skipping a number every 32nd time.
Seems strange that this is reverse of what is noted in this thread. The following code skips the 32nd item instead of duplicating it and goes from 31 directly to 33.
Actually, it’s the same behavior both times. When a number seems to be skipped, it’s because the assignment statement that increments the counter is the first statement in the loop, and it gets implemented twice. When the number appears twice, it’s because the assignment statement that adds to the array is the first statement in the loop, and that gets done twice.
If you change until 70 to until n = 70, then 32^1.3, and 64^1.3 appear twice each in the displaydata. 32^1.3 is 90.5096679918781, and 64^1.3 is 222.860944203808.
So the problem seems to occur when exiting the loop depends on a true or false condition.
I think you have that backwards. There have been no problems reported with For loops, and when Tom used Until 70 as his end condition, he didn’t have a problem either. The examples that have had problems have had stoploopif or until statements with a comparison operation as the end condition. Those that used internal counters had no problem.
The procedure that started this thread had only 3 statements within the loop. I wouldn’t call that complicated.
If you are actually concerned about performance Dave’s arrayfilter solution is probably at least an order of magnitude faster, maybe more than one order of magnitude.
This seems like it may well be a useful clue in debugging this problem.
This post was mentioned in another post today, which got me to revisit it. The bug described has since been fixed. However, it got me to thinking that there is a much nicer way to accomplish this in Panorama X, so I’ll describe that here for any future readers.
let n = 6
let Z = exportdataarray(generatedataarray(99-n,{seq()+n}),",")
That’s it! Just two lines, and this will be super fast.
