Printusingform problem
I had problems with printusingform not working in Pan 6 and still have problems in Pan X. This is my pesticide use report that has a header, data, and footer tile with with Image Objects displaying the state form behind the text. If the procedure opens the actual form to print, it works fine. If I use printusingform, it does not print the Image Objects.
