I have a Popup Menu button that in Pan 6 uses info(“Files”) to show a list of all open files, even those opened secret. Selecting the file then opens it. Pan X only lists the active file.
You can always test any menu formula by using it in a Text Display Object to see the results.
Based on what you’ve described, your menu should be getting a correct list, but my money would be that you’ve got some other error in the menu set up. How about sharing a bit more info about how you’ve configured it.
That’s a good tip, but it’s usually even easier to use the Formula Workshop.
Remember, none of us can see what is happening on your screen. The more context you provide, the more chance that someone can help you.
