I have a popup button that in formula mode will offer me a list of records that have been flagged that I use a chr(13) to delineate. I update a Permanent Variable used in the procedure. If I make changes I simply update the permanent variable. And I update when the database is first opened within the Initialize Procedure.
It was my most challenging transition from Pan X but with several adjustment to the code I got it working. Hurray. The original Pan 6 version is likely decades old.
Once working in Pan X I decided to copy the button and paste it into another form.
It did not work.
I troubleshooted it. Everything looked fine but no dice.
Tried the same thing on the same form. No success.
Eventually I took the procedure from the original, copied it, and overwrote the procedure in the new button.
It worked! I replicated the problem several times and each time if I copied the procedure and pasted it in the problem solved itself, even if I copied the procedure from the pasted button that was not working and then pasted it back in onto itself! Problem Solved.
The procedure was a Call statement. See below. One Line.
A strange issue but hopefully I will save some folks some puzzling misery. God knows how many time generosity on this discussion forum has helped me.
Ventura OS with Studio Mac (Apple Silicon)
