I want to play sounds when a procedure is executed but would like that the sound can be chosen or a variable vs. Hard Wired.
I am using the following code:
Playsound “/Users/George/Desktop/Address Master - Panorama X/Pan X Sounds/Stetson.mp3”
The above works fine but If I give the mp3 file name a variable it does not work.
like below
Playsound “/Users/George/Desktop/Address Master - Panorama X/Pan X Sounds/LSoundName”
Even though a File Global Variable is given the file name:
FileGlobal LSoundName
LSoundName="Stetson.mp3"
I have even assigned a FileGlobal Variable the entire file path with no luck.
Is what I am trying to do possible?
Thanks
