This version must be manually downloaded and installed (as I expect for all beta downloads for the forseeable future). Here is the link.
http://www.provue.com/downloads/sparkle/PanoramaX/3252/PanoramaX.zip
The changes in this release are:
The Panorama client now always disconnects a database from server when it closes. In the previous version, this did not work if the database was secret (no visible windows), or when closing the database via a procedure instead of the close box.
The ∂QuitUsage timer is now invisible in the Timer Workshop unless locked timers are enabled.
The Left/Center/Right button in the Text panel (form properties) is no longer cut off on macOS 10.14 and later.
Note: I am not going to put changes between incremental releases (like those listed above) into the Release Notes in the documentation, since these won’t be of any concern to users that never see the beta versions. These notes will only be published here on the forum. If there is a change that will be noticeable for non beta users, I will add it both here on the forum and in the documentation Release Notes, however, I am planning on putting all 10.2 changes on a single Release Notes page, no matter what beta release they are added to.
(I’ve corrected that condensed topic summary, obviously the one above is wrong, but for some reason the forum software isn’t grabbing the updated version. Probably a caching issue.)
