A new version of Panorama X is now available. If you’ve already installed 10.2 b30 or later (and I sure hope you have), you can simply choose Panorama>Check for Updates to install this update. If Panorama isn’t currently running, it will automatically offer to download b32 when you launch PanoramaX. If you haven’t installed b30 yet, you can simply go to www.provue.com and download it and install it manually (just download the trial).
This release contains bug fixes.
- Fixed crash when right clicking on blank area of Help window (or actually, any web browser using the WKWebView class).
- Fixed the “Prevent early abort of procedures in this database” option in the Database Options dialog.
