Panorama 10.2.3 - All menus are unresponsive.
I downloaded a new app, same result with new app.
Please help
Please help
When you say you downloaded a new app, did you mean the experimental app Jim provided, or was it simply the latest formal release?
Fixed it for me! Thanks
Worked for Me!
With the current, non-experimental version, If you click on the Apple menu, then you can slide over to a Menu in Panorama and get access to the popup (drop down).
if you click on the Apple menu then you can slide over to a Menu in Panorama and get access.
Yes, this was part of the original report a couple of weeks ago.
In any case, the new 10.2.4 version has just been released with the official fix for this problem.
Thanks for your help. My issue is now fixed. Best regards
