While it seems that every other Open… statement works with a variable, OpenPlain does not. It won’t compile. The workaround is to use OpenSecret but requires extra steps to get to the desired point.
This works:
Let lvFile = "Contacts"
openfile lvFile
This does not and gets a compiler error: “Unknown statement: lvFile”
Ahh, but as it turns out, none of the above are correct. OpenPlain requires no parameters. So the error is in trying to identify the file to be opened.
Openplain is a standalone statement that opens an open file dialog for me to choose the file that I want to open plainly. It even says so in the Help as long as one thinks while reading the Description.
