Good evening,
The hard drive on my iMac crashed so I have re-installed Pan X on a new iMac using the .zip file on provue.com and I have validated the install with my credentials.
Everything seems to be working except the following:
Under the sum menu, section “Summarize & Analyze”, I have a saved routine that is to work with just the set of data that I have selected (for example, all entries for Feb 2022). This worked fine before but now when I run the routine it gives the totals for my entire database.
Thank for you words of wisdom, as always, on how to fix this.
