I have a contact db. In the db there is a field for an emergency contact person. The emergency contact person may well be in the same db.
What is the best way to connect a person (record) in the db to be the emergency contact for another person (record)?
Hope that makes sense!
You’ll need some identifier, a field, on each record in order to enter a name or a record ID of the Emergency Contact. Clairvoyance can help you with accurate entries.
Then have a button and/or procedure that grabs that identifier and uses it to select the Emergency Contact.c
