I’m not sure whether I have misunderstood how this should work, or whether it is not working properly. I am trying to pull information from another database for individual records as required. I have the information set up for the normal situation, but occasionally there is a change. I thought if I had prepopulated a field, and used the code below, that the repopulated field would be left alone, and the empty fields would be populated with the data from the other database. However, at this stage, all the matching fields are being replaced with the new data.
joinonerecord
“DATABASE”,“TaxCategoryDefinition”,
“REPLACEEXISTING”,“NO”,
“CLAIRVOYANCE”,"",
“SOURCEKEY”,“Category”,
“NOMATCH”,"",
“AUTOJOIN”,"",
“KEY”,“Category”,
“MATCHINGFIELDS”,“YES”
