Is there a way to add right-click copy?
I use a data sheet oriented DB to keep track of all my apps, their registration codes, and support contacts. In that database, and others, I find myself clicking into a field with the desire to copy it’s contents for pasting elsewhere. But Copy is not a Right-Click option in that case (only various Selects).
I could use the edit menu or Cmd-C, but the right click feels so natural.
Is there a way to add it to the optional Right-Click actions?
Double-click to open the cell, then you can right-click to get the contextual menu with Copy
Yes, it is possible to customize this menu.
Here’s a right-click option with the Copy Cell command in it.
filemenubar "",
    menu("Context Menu")+
        menuitem("Copy Cell","CODE",{copycell}),
    "DATA_CONTEXTMENU"
Ah, the old, “… double click in the field first …” routine :exploding_head:
And a way to add it to the contextual Menu.
Thank you, both Jims.
