According to the new documentation for web browser programming,
To invoke JavaScript code from Panorama, use the script (or javascript) action. This action requires two additional parameters - the JavaScript code to run, and a field or variable where the result returned from JavaScript should be placed.
objectaction objectID,"script","... javascript code ...",result
The result parameter is optional. You should leave this parameter off if the JavaScript code doesn’t return a value . . .
Before b31, doing what I could with Javascript with minimal documentation, I found that the fourth objectaction
parameter was not optional. Reading the above in this context I assumed that had changed in b31 (and b32), but it seems not… Omitting a variable in which to return a result results in the error
ObjectAction: parameter is missing
Not a major point, but it would be tidier, and make code less obscure, not to have to supply a return variable if there will be no value returned by the Javascript.
