I have a database with several fields, one of which is a photo of the item for that particular record. I created a Form for the printed output, and following the tutorial for an Image Display Object inserted the proper photo for each record in the “Image” field. As I scroll through the records for the Form each photo appears as it should. However, when I select File>Preview, or File>Print for the form, that various text fields show as appropriate, but the photo does not appear. It has to be something simple, but what am I missing?
This is a known bug.
The scale to fit worked fine. Thanks
