My suggestion on business cards printed from an Employee file did not include the trick to get 10 copies. This is not intuitively obvious to the new Pan user. Pan does not automatically save changes and has a statement called “Revert” which reloads the last saved version of a file. That means a procedure can preform operations on the file that destroy the data then discard those changes. After selecting the employee’s record, use the DuplicateRecord statement nine times so you have 10 records. Then print and Revert.
