How do I search a record’s unique ‘serverrecordid’ as a searchable field and select one?
info(“serverrecordid”) function
The Panorama X info(“serverrecordid”) function returns the unique ID number for the current record.
How can I select a record in a database for a specific ‘server record ID’ for that record?
In the past I had a field that contained a uniqueID number created when the record was created.
Jim advised against that with the current state of Panorama.
Can I avoid having to populate the serverrecordid( into a field in the database and then select the serverrecordid( I want?
My initial need is quite simple. I want to only select the active record. For printing, as an example. Not all that satisfied my selection criteria.
How do I treat a record’s unique ‘serverrecordid’ as a searchable field?
