I want to make the first field active so I don’t have to select it.
You just use the Field statement.
Note, you can specify the field either by name, or by number, so
Field 1
will get you the first field, whatever its name might be.
Yes, I know how to get to the field, but how to I make it active so I can start entering data right away? Is their a command for this?
Use the editcell statement following the Field statement.
