I think this (propagate) is the problem.
Statements that only deal with summary records will work fine in shared databases. This includes GroupUp, Total, Count, etc.
The Propagate statement, however, will modify any record with an empty cell, whether it is a summary record or data record. If you have data cells that are empty in the column being propagated, this is going to be a problem.
Now that this has come up, I’m pretty shocked it has never come up before. Panorama 6 Server would have the exact same problem.
I think either a new statement is needed, or perhaps the propagate statement needs to work slightly differently if a database contains summary records. In any case, there definitely needs to be a way to “propagate” information into summary records without modifying any data records.
On further reflection, I think no new statement is needed, but the propagate (and similar) statements needs to work differently if summary records are present. If anyone thinks differently, please speak up ASAP because I will probably work on this soon.
