It was listed as on the “honey-do” list for features remaining to be brought up from Pan6. I don’t see any sign of this in 10.1.2. Is there a workaround other than multiple clicks in File>OpenFavorites.
TIA
While you can use an .Initialize procedure in your main database to open accessory databases and windows as you need them, PanoramaX has a new feature located in the menu File > Database Options … > Auxiliary. Read about Auxiliary Databases.
