Converting change statement from Panorama 6 to X
I am transferring a procedure from Pan 6 to X and it won’t run saying that I have a syntax error.
What I am trying to do is to select from certain fields a T and trying to lose that T from that field.
Here is the Procedure that won’t run, I guess it doesn’ t like the “”.
So how do I change this???
Here is the Procedure to change:
Field “14-Driving Rank”
Select «14-Driving Rank» contains “T”
Change “T” “”
Field “12-Fairwaysrank”
Select «12-Fairwaysrank» contains “T”
Change “T” “”
Field “16-Greenshitrank”
Select «16-Greenshitrank» contains “T”
Change “T” “”
Field “18-PuttsRank”
Select «18-PuttsRank» contains “T”
Change “T” “”
Field “20-GIRRank”
Select «20-GIRRank» contains “T”
Change “T” “”
Thanks
The Change statement requires a comma between the parameters. It’s missing in your code.
The change help page provides detailed instructions on how this statement needs to be adjusted when converting from Panorama 6 to X.
