Two files, each with its own “.Initalize”. In one the line ( openform "Form_A") is tagged as a syntax error. The .Initialize in the other file has the same code (although its own form name) and gets an OK.
The error survives a manual respelling (the original spelling was brought forward from the previous v6 file).
The syntax error has not to be exactly in that line; it can be in the previous or the following line. So commenting out this line is a good advice to locate the real cause of the error.
I tried, line by line, all 13 of them, and the “Syntax Error” remains. Oher things which don’t work in this window are:
1.) CMD-D should single step… … it doesn’t
2.) CMD-/ should toggle back/forth “Comment”. For a line already commented out, it simply adds a “//” to the existing "/*
(I should also say that v10 is surprizingly sluggish, often taking 5-10 seconds to execute a simple command.)
Read 'em and weep, Gary . (The other things not working here is that after the “/*” is removed, the lines are still green.)
global gwho, gNish, gwindow,
openform “Form_A”
openform “Form_B”
gNish=“x”
gwho=“”
hide
Field Out
Select today()-Out ≤ 365
Field Age
«Age» = ?(Category≠"Lost",?(In=0,today()-Out,In-Out), 0)
Field Name
RemoveSummaries 7
show
The problem is the extra comma at the end of the first line. Because of that, it thinks openform (on line 2) is the name of a global variable. Then it sees a quote character where it expects a statement, and boom, that’s a syntax error. Note that this also would have been a syntax error in Panorama 6.
