I hoped magicforwindow could help in this situation, but it didn’t.
Adding to this report, if I click away from PanX and then click back on any PanX window (returning focus to PanX) before the closewindow statement is executed, the error message is still generated.
I believe this is because the closewindow command stops a procedure from continuing. There was something like this in conjunction with the print dialog. You can search for that topic here.
I’m guessing it stops if the closed window is the last visible window in the database running the procedure, I have not confirmed this. In my case, closewindow is closing a second open window in the same database, leaving the database still open to complete the procedure.
Actually the procedure will continue to run even if the database that contains it closes. The Procedure will run to conclusion unless there is an error or Panorama X itself quits. I just confirmed this with this code on a test database:
closefile
wait 10
message "OK"
Sure enough, 10 seconds after closing the file the message popped up.
I actually think this is working exactly as intended. The documentation says:
This statement closes the currently active window.
When Panorama is not the frontmost application, there is no currently active window. Only the frontmost application can have a currently active window. I’m sure you were thinking whatever the frontmost Panorama window was was the active window, but that’s not the case.
Yes, that won’t help because it only works within Panorama, it can’t affect the fact that Panorama is not the frontmost application.
You may want to use info(“panoramaisactive”) to check if Panorama is active. That way you could give a different error, or you could use bringpanoramaforward.
That did it Gary! Part of the trick is the second openform “Test” that you added. Without it, the error message still shows up, instead of closing which ever form is front most.
Then I tried the following, but still doesn’t work:
Had a thought that it might be wise to change the AppleScript to get the name of the current Panorama X application in case more than one version is currently running.
applescript {
tell application }+quoted(info("panoramaname"))+{
activate
end tell}
Of course if Apple ever decides to deep-six AppleScript we are back to square one.
I’m glad to hear it. But I’m also puzzled, because I would have assumed that the bringpanoramaforward statement uses the same API that AppleScript uses when you activate. Perhaps I’m not correct about that assumption.
I later tried the exact same code but using bringpanoramaforward instead of the AppleScript and it worked for me without an error. Don’t know why one worked for Hugo and the other did not.
Were you able to confirm that you saw an error with Hugo’s original code? I think he is using shared databases so that may be required to see the error.
I got a CloseWindow error when I left Panorama X before the last two lines executed but the procedure window was brought forward so the bringpanoramaforward statement evidently executed ok. Also got the error when I substituted the AppleScript in the above code. If I add the second openform statement before the closewindow statement I do not get a error using either th AppleScript or the bringpanoramaforward method.
