Hello,
I have a field called ‘Status’. It is a ‘choice’ field. Today, I added an additional choice (‘missed’) to the list of pre-existing choices. However, in the choices panel (In lists view), the new choice, ‘missed’ is not being rendered correctly: it appears on the dropdown list, ‘stuck up’ - why might this be so? Thank you! (The problem remains even after I restarted Panorama). (M2 PowerBook; macOS 15.5)
You accidentally put an additional cr or lf character after the word “Missed” in the Choices property. You can verify this when you put the cursor in the white area below the last choice option.
Thank you @admin @designer @KJM
@KJM Following your post, I checked. It appears that I inadvertently added two carriage returns. Once I have deleted them, it the ‘Missed’ renders as expected.
Sorry for creating problems!
Thank you again!
No one ever needs to apolgize for having a problem or asking a question. That’s what makes this forum a success. People are more than happy to step in and offer solutions, just as Kurt did here for you.
Believe me, we’ve all made posts that we later felt were dumb. But, as they say, the only dumb question is the one you don’t ask.
@JamesCook Cheers! I am grateful for the community’s generosity!
