Hello Everybody,
I have a field which contains a text array. A typical record might have the following entry:
99; 8.3
106; 12.7
62; 5.2
Each record will have a different array, and there may be more or fewer elements. But there is always at least one element.
What I need to do is to remove all elements in which the last number is greater than 12. In the example above, that record will have the second element eliminated. I plan to ARRAYSTRIP when done so there are no empty elements in any record.
I tried the following:
FormulaFill ARRAYFILTER(«myField», ¶, ?(val(array(import(),2,";")) > 12,
"", import())
The syntax of this line is OK, but when the macro runs I get the error message:
Runtime error on call( procedure
Is there an expert who can advise me what’s going on? How can I accomplish what I want to do?
Regards,
Vic
