I have a procedure that changes the location multiple objects in a form. If I move away from Panorama to a different application while the procedure is running, I get the following message:
If you use either magicwindow or magicformwindow before and after the changeobject statement it would allow the changes without generating errors even if Panorama X is not the currently active application or the form is not the front-most even if Panorama X is the active application. I use this method extensively in my Pan Audio Player file to keep the player display updated at all times.
