Sorry for such a stupid question…but I am a longtime Pan 6 user and just getting used to X So how do I add 2 numeric fields together and get result in 3rd field?
Third field = NumField1 + NumField 2 ?
In a procedure, you would do it the same way you did it in Pan 6.
Field "Third Field"
FormulaFill «First Field» + «Second Field»
If you are doing it from a menu.
That will get you a dialog that is similar to the one in Pan 6.
Thanks so much…sorry for such a dumb question…but Pan X is not quite a s easy as 6 but I will get there
Thank you!
