Word Processing
Please forgive me if this has already been discussed. Is the word processing with mail merge from the data base available in Pan X similar to Pan 6?
Panorama X does not currently have a word processing object. However, you can do mail merge with styled text by using the Text Display object and using rich text tags. You can find rich text in the Panorama Help (search for rich text) or on the web:
Rich Text
The topic you are interested in is about a quarter of the way down the page, look for the Embedding Data in Rich Text section.
Thanks Jim. I will give it a try. I have been busy the last two weeks redesigning all my forms. The one thing I really miss is the alignment “snap to” lines. It was so helpful. I can still do it using the coordinates.
That is on the list of future enhancements.
