I am trying to export some data out of PanX into a text file that can be read and imported by Pan6. To export I used the following commands:
local fileChoice
savedialog fileChoice
export fileChoice, tab() + First + tab() + FullName + tab() + tab() + tab() + tab() + tab() + Email, cr(), “Mac OS Roman”
Rtn
The resulting text file can be opened with PanX or Apple Numbers, so it seems to have been created propertly. However, I can’t get Pan6 to import the file
To import into Pan6 I used the following commands:
Local folder,filename,type, typelist
type = “TEXT”
typelist = “”
openfiledialog folder,filename,type,typelist
if filename=""
stop //* the user pressed the CANCEL button */
openfile “&”+folderpath(folder)+filename
I get a Panorama 6 error message saying:
Sorry, only Panorama, OverVUE, or TEXT files can be appended.
Any ideas?
